SpeedRacerX
- Jan 20, 2014
I think it has a LOT to do with the weather. It was 90+ degrees and humid the day this happened.Exactly - no one else thought it would be a bad sensor either! Maybe I just finally got it set correctly, but everything was set several different times prior to the new one. The gears were fairly worn on old one - maybe enough to cause issue when hot?
Do you think it had anything to do with the weather conditions? I am wondering just how much it affects it - i am losing up to 2-3 lbs of boost when everything is hot...
