Misfiring at idle, Please help
  • Thread starter Thread starter buick86turbo6
  • Start date Start date
B
buick86turbo6
Guest
I have an 86 TR that i bought for cheap, i guess you could say that its a restoration project (can't afford nice TR, only 18 y/o). I have had the bodywork and paint taken care of already. But anyway, when it is idling (if you could call it that) it misfires like you wouldn't believe. Here's the kicker: i have replaced the plugs, wires, and coil pack. She has 95K on the factoy motor and i have replaced the crank sensor. I'm thinkin it might be injectors but i don't know. Any help would be greatly appreciated.
Thanks-Jon
How bad is bad? Check your firing order. And also check for vacuum leaks. At 95K, you can safely assume most all the vacuum lines are dryrotted if they have never been replaced.
