- May 9, 2002
Failed Emissions, Please HELP
Drove my Stock TTA 600 miles yesterday. Car was perfect when I started and had a minor miss at idle when I got home.
Emission Test Results: Passed the Fast Idle portion of the emissions test (135.0 PPM HC), but not the idle portion (527 PPM HC). Passed the other tests and the visual.
Got new plugs (43CRTS) to install tomorrow. Checked the plug wires good with impedance under 1k ohms. Put butane gas, via unlighted torch, around all the vacuum lines I could trace, no difference (it did sound a lot like other vacuum leaks I've had in the past).
If the plugs do not cure the miss, I'll look for some other things. Could I have an injector problem?
Any suggestions? ....Thanks
