I tore down my stock motor which I thought was unopened due to a head gasket failure. Well it's not unopened, timing set has been changed and I found 3 what look like hot-air pistons with the 3 notches forward and the other 3 pistons just have a sort of "punch" mark on the top of the piston facing forward. They are STD size. Is it possible the factory short block could have been built with two different piston styles? Maybe using up old stock?
