missfire /wet plugs
Favian Cuevas
Well I just recently got a t type but it wasn't running I got it to start but it will not stay on unless push on the throttle but it's missing like crazy I pulled the plugs an the plugs were all wet like it's over fueling or is not firing correctly I did change the fuel pressure regulator as well just in case ...
It does have 86/87 coil upgrade ...
Need help
Make sure the cam sensor is set right most times I've seen these cars have fueling issues like this it was usually the cam sensor. Also check the iac,tps,o2 sensor read the stickys for more answers it should help
Thank you ama start there an go from there an I will let you kno what happens .. by any chance do you kno how to set time on it
Go to vortexbuicks.com I believe they tell you there the timing is controlled by the ecm but the cam sensor has to be within specs. For instance when I first got my car running it was pig rich blowing almost raw fuel out the exhaust. The CS was 180• out
