missing under throttle
OK the miss started off almost unnoticeable and it will do it cruising under some throttle went out to drive it today and it started to get worse and then bad it hesitating off idle and breaking up bad now any idea what this can be any help appreciate
Scan master numbers
O2 875-890
Af 07-06
L8 41-44
Bat 14.5
Int 128
Bl 125
Mph 00
Clt 165
Ats 65
Rpm 850
Tps .42
Iac 35-39
Cc 93
And when it is sputtering o2s 111-220 If this helps just changed plugs and still doing same thing
I had Same issue it was the MAF and the coil pack fyi
Ohm your wires !!
Ck for a bad plug
Or injector
Go buy a replacement 02 and slap it in. God knows how many I've gotten from the crap stores that failed right out of the box. When it stumbles do you get a check engine light....and maybe at cruise it goes away?
currently cutting it the F loose
No light come on it tries to clears up the harder I run it but it hard to drive it normal with out giving it gas
02 crosscounts (CC) at cruise and when it stumbles.
