dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
If u think 93 Octane is good at 15lbs of boost throw a alky kit on and turn it up to 20-25lbs
it's night and day . It's like running race gas on 93 FYI
SignUp Now!Highly debated subject. Before the worldwide use of Ethanol began MTBE was used in our fuels as an anti-knock agent. When MTBE was banned in 2004ish a replacement was needed to control knock. Enter, Ethanol....Do you mean Non-Ethanol, or alcohol free Premium?
It would be better to avoid the pump gas that has ethanol mixed into it. There is one station in my area that sells what they call "Clear Premium" that is ethanol free. That is what I run. Alcohol is a bit corrosive to fuel system components, plus it attracts water.
Now, if you choose to buy Ethanol free fuel my question is: what anti-knock agent is used to replace Ethanol? This very question was posed years ago to our local gas companies and we still don't know the answer. We were told they are just trying to satisfying customer demand (and profiting by it of course) but still no word on what anti-knock agent is used in place of Ethanol, if anything. Maybe someone could enlighten me...
As far as ethanol as a corrosive goes, I know my lycoming O 320 ( opposed 320 ci carbureted 150 hp ) airplane engine that's made to run on 80/87 octane doesn't like it. The alcohol destroys hoses and the rubber seals in the carb. Even though avgas is expensive as hell ( at times $6 per gallon) , I would have to run that just because I couldn't find any auto fuel without alcohol. I'm not sure why it doesn't corrode the same for auto engines .
I think the most expensive part of having an airplane..... wait you have an airplane. playing worlds smallest violin for you on the fuel price!As far as ethanol as a corrosive goes, I know my lycoming O 320 ( opposed 320 ci carbureted 150 hp ) airplane engine that's made to run on 80/87 octane doesn't like it. The alcohol destroys hoses and the rubber seals in the carb. Even though avgas is expensive as hell ( at times $6 per gallon) , I would have to run that just because I couldn't find any auto fuel without alcohol. I'm not sure why it doesn't corrode the same for auto engines .
Ethanol itself is not corrosive. It is an FDA approved product used in thousands of everyday things we use i.e., vodka, perfumes, antiseptics, antibacterial products, face creams, just to name a few. So common sense will tell you it cannot be as corrosive as some claim.As far as ethanol as a corrosive goes, I know my lycoming O 320 ( opposed 320 ci carbureted 150 hp ) airplane engine that's made to run on 80/87 octane doesn't like it. The alcohol destroys hoses and the rubber seals in the carb. Even though avgas is expensive as hell ( at times $6 per gallon) , I would have to run that just because I couldn't find any auto fuel without alcohol. I'm not sure why it doesn't corrode the same for auto engines .
I worked at a motorcylce/powersports dealer when mtbe was replaced with ethanol. We saw and instant increase in the need to clean carbs that had the float needle and seat corroded together and pilot jets clogged with gel from the fuel. (Some poor guys carbs would clog after just a few weeks. ) Prior to this the fuel lasted longer in stored vehicles. Mainly unused snowmobile or watercaft were the ones needing carb cleans. ( stored for 2 or more years)Ethanol itself is not corrosive. It is an FDA approved product used in thousands of everyday things we use i.e., vodka, perfumes, antiseptics, antibacterial products, face creams, just to name a few. So common sense will tell you it cannot be as corrosive as some claim.
When you pull up to the pump at the gas station there is a yellow sticker that says "This product contains up to 10% Ethanol" or something to that effect. The verbage may be slightly different depending on where you live, but the point is Ethanol is the ONLY advertised ingredient in the fuel. Our fuel certainly contains many other unknown products/chemicals besides Ethanol that is not as openly advertised. I believe this is why Ethanol gets it's bad reputation. It is the only advertised product added to our fuel making it an easy scapegoat.
It is widely known fuel additive packages (the other products put in your fuel besides Ethanol) vary company to company - State to State. I suspect this variance may be the reason why some report problems while others don't. The problem some have with their fuel is not because of the Ethanol but with some other unknown, unadvertised, product being added to the gas. I wrote extensively about this subject in another thread a while back but only got crickets. I guess nobody wanted to hear common sense being preached because it was too easy to blame Ethanol for their problems.
I had to bust ur balls about it. all in good fun.My aircraft had an STC ( supplemental type certificate ) issued ( had to purchase it ) to allow usage of "auto fuel" . More than a few of my aviation friends had to have carbs rebuilt, rubber fuel lines replaced and fuel selector valves rebuilt when this STC first came out and they were using auto gas with ethanol. Those that were careful to use car gas without ethanol had no such issues whatsoever. I'm just sayn'.......
As far as the worlds smallest violin goes, a good bass boat , or a new car for that matter , cost more than the airplane did , and not a whole lot of cash to maintain provided you started with a good one. I am sure that quite a few TB owners have tens of thousands of dollars invested in their rides..... My wife's Subaru Forester cost a heluva lot more than my TriPacer did...
sorry about that! rough day, I meant non ethanol.Do you mean Non-Ethanol, or alcohol free Premium?
no,the car will run great on the 93/alky regardless if the tune is right.Question. Does this car need to run on non ethanol gas?
