I saw a post by TurboBob offering modded ECM's so you can run low imp injectors. Someone asked if you could run BOTH low OR high imp injectors and he said YES. Is this correct?
Over 15 years ago I upgraded to 55's and had my ECM modded by someone on the board. Large high imp injectors were not available back then so had to do that. NOW I have outgrown the 55's and want to go bigger but now there are large high imp injectors available BUT I figured I would have to go back to a stock ECM.
Then I saw his replay so can I really run high OR low imp injectors with an ECM modded for lows? I think they call them Peak & Hold drivers?
ALso, does this make a difference in the chip other than changing it for the larger size injectors?
