blownbuick
- May 24, 2001
Stainless steel Terry Houston downpipe that has been modifed to run with an ATR external wastegate. Option A would be to use it that way. Option B would be to convert it back to a stock type flapper setup. The hole for the original internal flapper has been plugged with a weld. We took some rough measurements the other day and it looks like the weld could be ground off to unplug that shaft for a flapper to be put back in if you wanted to go that way. There may have to be a little internal drilling done from the inside with an angle drill to finish opening it up. Of course, the modification for the external wastegate will need to be plugged as well to go back to a stock type wastegate setup. A bung has been welded into the pipe for an EGT probe. The pipe is in excellent condition. High resolution pics available upon request.
$215 + shipping
W. John Taylor
blownbuick@excite.com
$215 + shipping
W. John Taylor
