Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Modine 951 F-Body Radiator on a HA.
Been running this for about 4 years, no issues, but I have two questions.
1- How have you guys and gals been dealing with the 3/4" hose connection below the radiator inlet? (Besides just a rubber cap) Been thinking about running a hose from the heater outlet on the water pump to this connection.
2- Anyone know of a fan shroud for this radiator for a HA set-up? The shroud should be about 10-12" deep and fit this radiator. I am looking for a "clean set-up".
 ) I assume you are looking for a shroud that'll fit the stock mechanical fan?  I don't know of any off the top of my head, but when I was combing junk yards for the proper radiator hold down plate for the f-body rad, I was surprised at the variety of shrouds in similar sized GM cars... you may get lucky figuring out the dimensions you need and strolling the local you-pull-it with a tape measure. I'd be surprised if you didn't find something you could make work that looked factory.
