More new products from RJC Racing
Race Jace
Research, New Tech and Development
Staff member
We have a new Buick products available now, we have billet aluminum alt fans
that we chrome plated, billet aluminum alternator nut, billet aluminum
Idler/tensioner pulley that includes the bearing.
Some of you may have already seen these but for the rest here is the link.
http://rjcracing.com/RJC_Buick_Products/RJC_Billet_Alum__Pulleys/rjc_billet_alum__pulleys.html
we also have EGT kits for sale at very affordable prices.
http://rjcracing.com/EGT_Gages/egt_gages.html
products in the works;
#RJC-CSr Cam Sensor Repair kit.
we have made a simple bolt on part that will fix the cam sensors when they
break the tab off of the inner trigger ring. In the past if this has
happened you had to buy a complete new cam sensor which were very expensive,
now this repair kit will fix it for under $20. This will be available within
two weeks.
#RJC-OP New stamping deep sump oil pans. they will be just like stock pans
with a 1-1/4" deeper sump and a pickup tube extension to match. they will
have the drain bung on the outside of the pan. They increase the oil
capacity to approximately 8 quarts. they will be gold zinc plated just like
Moroso or other aftermarket pans. we are looking to retail these for under
$250 with everything and shooting toward the $200 range. We are trying to
get prototypes done so we can have some for display at the 04 GSNats
RJC-VC New stamping steel chrome plated valve covers, they will have
clearance for roller rockers and hopefully be able to install in a car equip
with ac while the engine is in the car, unlike other aftermarket valve
covers out there. The best part is we are trying to retail these for
$99/pair. we should have these available for sale at the 04 Nats.
RJC-14AF 14" Air filter. this will feature a 4" hose connection, cone
reusable filter that is similar to the K&N but will outflow it by 20%
Thanks,
RJC Racing always innovating and moving forward
Sounds good - put me down for some valve covers (send a pic first though!)
Scott
Will those pans be 14 bolt configuration and 20 bolt?
Norbs, these will only be available for the 20 bolt configurations. to tool up for something like this it is very expensive. the dozzen 14 bolt pans that i would sell would not even come close to recovering tooling costs. It is going to be tight for even the 20 bolt versions.
sorry
Jason, think you will ever make a shorter oil pan for use with a Girdle so it still hangs at the same height?? I think there have been a few who didn't want to run a girdle because of that issue. I know it is an issue with a TTA
I just figured it would be nice for a offcenter stage block, i guess theres not that many around, I got an idea though, just dont make the holes i will drill them my self. Something to think about!
