More Power Plate Results
GNASH
Before the plate was installed I had a pretty severe part throttle knock...as much as 6* (on T-Link)when I punched it from a roll up to about 60 mph. Took 35 minutes to install the plate and now I have NO part throttle knock at all! Haven't had a chance to do a run on T-Link at WOT to 100mph+, but so far I'm convinced this thing does the job! My idle is much smoother too.
...also drilled out the EGR hole....
Let you know more findings when the I can do more tuning. From what I have seen, I should be able to get ~1.5 psi of boost at WOT. We'll see.....
Derick
