The Darkside
Heavy Metal Thunder
- May 25, 2001
Questions about the Translator/ Translator +
When you have the Reg. Trans., you CAN adjust your base fuel settings, but you CANNOT adjust your WOT fuel settings?
The only way you can adjust your WOT fuel settings with the Reg Trans. or the Trans. +, is if you have the extender chip?
If you have your own chip & want to be able to adjust the timing in it, you can do so if you have the Trans. + ?
The extender chip also allows for your Mass Air Flow Sensor to be able to read up to 512 Grams of air Instead of 255, so you can adjust the WOT fuel settings & it lets you be able to make your own chip & put whatever timing & fuel setting you want in it?
Ramchargers can put any other special features you want in the extender chip before shipping it to you?
The Darkside
The Darkside
