Please bear with me guys..I am new to the boost game.(I am an NA LS1 convert).
Couple of questions. First, I pulled the valve covers to adjust the rockers when I noticed there was water in the bottom valve cover bolt hole. Is this normal, or should I be wary of this. I noticed that the bolts had sealer on them, so i am assumiong that this may be common.
Second. I was looking around the top of the motor and noticed a brass t fitting that had vacuum lines running from it. Is this a boost controller? If so, do I adjust the boost level with this or the waste gate rod? Also, this was kinda sitting on the fuel rail. I have noticed some wierd kr levels on the Scan master and was wondering if this could some how be causing false knock. As of now I dont have a clue where the knock sensor is on these thing( I know that they sit on top of the valley cover on the LS1).
Third. I am going to take this car to the track Sat night. I have a race chip that is set up for 25-27 psi on 112 r/g. Am I risking detonation problems by running 110 on this chip. I have Alky Injection. Do I leave it on with the race gas, or is this a no no.
All help is greatly appreciated.
