More Winter Storage ?
Paul Clark
Unheated garage, with probably plenty of moisture and condensation.
Store the system empty or full.
And what about "Heet" or possibly fuel stabilyzer (or however you spell it)?
No boost going to the storage area, and will pump out everything before re-starting in the spring.
Paul
The pumps when shipped from the MFG come with water in them. That is how they are shipped.
Heet=methanol
I dont care to let anything sit in 100% methanol for extended time periods.
So.. my suggestion is flush alky out.. and if you want to make sure there is no issue.. mix some water with the alcohol.. that will take the bite out of it and any residual left in the lines and pump are a non-issue.
I wouldnt leave straight water in it filled.. as it can freeze and cuase issue.
HTH
