SignUp Now!Morel roller lifters with Comp Cams 941 springs, set at 130 open and 350 closed.
You may have those reversed.
Bob
Crane (Calico Coating dry film lube) ( don't remember the part #) dual springs
145 closed
400 open
424 spring rate (this is important)
installed @ 1.840 on TA aluminum heads
6000 RPM shifts @ 25 psi
Scorpion hyd. lifters
.030 preload
So for the spring rate, are you saying higher or lower is better?
Been looking at some springs made by Manley
They are 150@1.810 on the seat and 405@1.150 open.
Spring rate 379
part #221436-16
To my knowledge so far they have been run as high as 160 on the seat. somewhere in the high 300's open is about it
