Moroso Drag Spring Question??
Justa6MB
I just purchased a set of the above and put them in. The passenger side appears 100%, but the drivers side is a lower spring. It's short enough that with the shock installed and the car jacked up the shock isn't in the mounts? So basically unloaded it's free to move around? Is this ok? Seems odd to me. I realize with weight on it it will sit in position.
DS
assume you're talking about moroso rear trick springs and not front drag springs
rears as a set arent mayched springs and have two different spring setups , if installed properly the passenger side should have more pressure than the driver so having a looser driverside spring makes sense
