From what I remember the way the lower mounts are shaped or designed it wouldn't even matter if they were cut off the tubes and rewelded. I know the shocks are still going to be a problem with the new rear that they sent me. My plan is to get the lower shock bolt lined up the best we can while its in the shock, tack it in place, take the shock off and weld the bolt into the lower mount. I cant see any other way of doing it. One of my friends out in MN has the exact same rear in his 79 Malibu and he had no problems. He also used non adjustable Hotchkiss upper arms which is exactly what I have in my 81 Malibu. Cant figure out how his fits and mine wont. What pissed me off is its supposed to be "made for the car" and its really not. I had to modify both backing plates when I first got the rear because they were hitting the lower arm mount. Not what I expected for close to 3K. I was going to buy a Currie 9" before I bought the Moser. I ran into someone that actually knew Greg Moser and he told me that they were a great company to deal with. That's why I bought the 12 bolt.
Maybe you should post on a few other g body sights to see if anyone else has an come up with a solution before you send your back. Just a thought.
