J-B Racing
Forced Induction
- Sep 16, 2003
Yup! Got to maker happy...
So here we go!
1- Good Year Slick Tube for 10.5" $30
1- Slick Tube for 8.20" $30
1- used Blower Motor $20
1- Turbo Bracket "J" $30
1- 10" Electric Fan $40
1- EGR Solenoid $30
2- Injector Harness $20 each
1- Dash Plate Driver side $70
1- Dash Plate Passenger side $100
1- Vacuum Canister $30
1- Auto Meter C2 Boost 2/18" $40
1 Auto Meter C2 Oil Temp 21/8" $40
6- Speed Pro Pistons on Rods .030" $300
1- D5 Converter $100
2- Flex Plates $20 each
2- Stock Turbo Inlet Bell $20 each
2- Stock Turbo Exhaust Bell $30 each
1- GN Cat Hanger $65
1- Plastic Inlet to stock Air Filter NEW $60
1- Trans Cooler 11" x 12" x 1.5" 3/8" $50
1- 3" Aluminum Flange Connector $50
9- Hood Insulator Inserts $30
2- GN Radio's with Equalizer 1 Dial and 1 Pin type $120 each
1- GN 87 Manual Heater Control $40
1- set of Air Bags with hoses $50
1- set of 8445 Heads refresh $300
1- Test Pipe 21/2" $20
2- Crank Pulleys $40 each
1- AC Comp. "L" Bracket $25
1- Custom made Crank Trigger $40
2- Converter Shields $20 each
2- GN1 W/G Springs $20 each
1- 86-87 Chrome Grill EXELLENT Condition $100
1- 86-87 GN Front Bumper $200
1- 87 Heater Core used $20
1- K&N Filter 5" Inlet x 10" $40
1- 109 STD Block $500
1- GN Upper Heater Box $40
1- Alky Pump $30
1- GN Oil Cooler Filter Adapter with hoses $40
1- K&N Filter 4" Inlet x 12" $40
1- stock rockers & pushrods $40
1- R/R Wheel molding used $60
1- R/L Wheel Molding used $60
1 Brand New R/L Wheel Molding # 20498650 $175
1- set of front Bumper Flasher Bezels $40
6- Stock Rods $60
2- S/S J Pipes $30 each
1- Stock Fuel Reg. $10
1- GM Manual Master Cylinder $30
1- Power Master Brake Pedal $40
1- Power Master Firewall Adapter $50
1- ATR 02 Monitor $60
1- L/S Inter Cooler Bracket $50
1- GN Turbo Oil Return OE $50
1- Heater Pipe on Intake $60
1- Stock MAF Sensor core $20
1- Ign. Coil Rear Bracket $25
1- Throttle Body Pipes $40
1- Casper Engine Harness Front part $60 NEW
1- Light & Dimmer switch $30
1- GN Buzzer $20
1- GN Trunk Switch $20
1- Map Sensor $30
1- MAP Harness New $15
1- Module Bracket bottom $40
1- Bosch Wide Band # 17014 $60
1- NGK Wide band # 24302 $80
1- ESC module New $45
1- Coil & Module combo used work great $150
1- Stock Valve Covers $50 or $60 Glass Beaded
1- WW Bottle $30
1- Anti-freeze Bottle $30
1- Inter Cooler Bottom Bracket $50
2- Trans Mounts $20 each
1- Stock Water Pump Pulley $30
2- Hurst round Shifter Balls $10
1- Hurst round Shifter Ball with Button $20
1- GN Turbo Breather Pipe to VC $25
2- Reds Chips for 72 psi $20 for stock MAF
1- TT Chip for 72 psi $20 for Stock MAF
1- Power Master in parts without Motor $100
1- 4" x 3" Hose reducer $20
5- Various Hose Adapters $20 each
5- 4" S/S Angle Pipes from Burns $30 each
1- 4" S/S straight Pipe 36" $50
I have pics for all parts. Most are used and would be shipped USPS for low cost shipping from Canada.
Thanks for looking
1- EGR Solenoid $30
1- Alky Pump $30
6- Stock Rods $60
1- GN Buzzer $20
1- Map Sensor $30
1- WW Bottle $30
Thanks for looking
