I've just inspected the crank with the main caps off. I didn't measure the crank endplay again, and what would I be looking for to check the crank thrust bearing? The slinger appeared fine to me, there is a washer between the slinger and where the hub seats - again all looks good to the untrained eye. The turbo drain was just the picture, it is clean and clear. I can post a picture later of the material. I cleaned it out of the pan and the actual material may be less than what shows in the pan. Also it will not stick to a magnet. The other question is the thrust surface on the cam appears to be the same color. Is that a possibility? What was the material that the budget roller cams left in the pan? This material is mostly flaky.
