Hey Guys,
I am considering a new motor build for my TTA (acutally another motor, as I plan to pull my stock on and put it on a stand).
I have a basically new GN fully built 109 block that I am considering taking apart for parts. The reason I am not going to use the short block is that is was zero decked.
Now onto my first question. I have a set of .020 JE pistons in the GN motor. What do you guys think of using a used 109 block (assuming it was not decked) with GN JE forged pistons and TTA heads? I am planning to run RJC's steel headgasket kit. I don't mind if the motor is in the 9 to 1 cr, just don't want to go much higher than that?
I plan to run my GN rods, girdle, ARP bolts, ATR 214/210 billet roller. Then get another set of heads and have them cut for larger valves (have a set in the GN heads) and have them polished.
The GN motor has roughly 1000 (or less miles on it).
Let me know what you guys think!!!
