My questions is pretaining to the prep of the build of a 109 motor. Block is already set up with billet caps,30 over, crank is 10/10, you get the point. My plan is to build the bottom end pout GN1's on, HYd roller,ported intake, 70mm turbo, looking to tun low tens.
Is there mods that should be done to either the block or the timming cover ?
