8 85Grandnational Guest May 3, 2002 #1 Can anybody tell me if the motor mount positions are the same for the turbo 6 and the v8 regals? and are the the same mounts? thanks
E elcaminov6 Guest May 3, 2002 #2 I don't know if the mounts are the same or the positions are the same either, but the crossmember has all the holes in it for every motor they put in the g-bodies. You have to drop the lower control arm to change mounts.
R rastaz aka 80's Rob Joined May 26, 2001 May 3, 2002 #3 Motor mounts and the brackets on the frame are different from the V6 to the V8.
