I put a '95 LT1 motor into my IROC, and hooked it up using DFI. To fire up the motor, I used a program off the internet from someone who had a somewhat similar engine combo on ther DFI v6.32. So I uploaded his file, and the engine idles and low revs (to 2500 RPM) very well and smooth. Not lean or anything. I put on a free flowing exhaust, new air filter, new ignition coil, new spark plugs, new opti-spark, new fuel pump (Walbro 255LPH), 24# injectors used injectors. My motor ONLY revs to 3000 rpm, then it stumbles like it hits a rev limiter. The tach jumps all over the place at that RPM as well. What do you think it can be? Can the DFI program I'm running be too advanced in timing? I'm looking for any help I can get as I'm stumped. Could this problem stem from fouled spark plugs, or maybe a bad ignition module? I'm looking for any help I can get...please respond. Thanks.
