motor position and mounts
bad2bone
badtobonebuick.com
involved in an accident front end damage at 25MPH - suspension components good and did NOT damage fan intercooler - does NOT appear to be any issue with motor mounts. Motor seems to be off center and I can't recall if it was originally like this or not. At original state was the motor placed perfectly straight as viewed from front of car?
Sounds like dumb question I know but I cannot recall.
Will Add photo ___ although the angle of photo and proximity of motor may be difficult to see. I have original photo and extremely difficult to make out - possibly I can photo enhance.
Did you check back mount (transmission)
Look at down pipe and cat. Mount
That’s a great point, the trans mount is pretty easy to break and if it’s busted you’re engine could be jacked to one side a little. Take a look at that trans mount on the crossmember.
I had somewhat of the same problem, I would check trans mount, mount to frame and block. Is it tilting back or side to side?
