Hi loads
Hi,
From my experience, a properly operating R4 compressor doesn't take a bunch of hp to run. However, R134a is not the same as R12; high side pressures are very much above the 12 , and pressure means extra drive power needed. I would suggest a change in refrigerant may help. RB276 is my favorite. It is a blend, contains it's own oil, and has very similar properties to R12.It may be coming to be hard to find, as it is deemed obsolete,but I believe it is still on the safe and legal list. It will lower your head pressure at least 50 psi on a hot day.
I realize that you are talking about an initial startup drop in rpm, but these compressors were designed not to do that. Compared to the A6 they replaced, there was a marked decrease in power consumption. Not until the V5 and DA6/ HR6 compressors, did it get any better.GM used the R4 until the late 90s, well beyond the 134a changeover.
If you continue to have what you consider to be excessive power draw when the a/c is engaged,i submit that there are issues with the unit itself. Rebuilt compressors are like anything else;you have to watch what you buy.
Good luck with your concerns.
