Motor/trans mount question
#1
Looking into getting motor mounts and trans mount .
I know Poly mounts are best. But is it possible to use new stock mounts (non-Poly) on a let’s say 500hp engine ? Or will that be too much stress ?
Or has anyone just changed the Driver side to a Poly and Leave the passenger side stock ? New of course. I heard most do this ?
Trans mount .....stock or Poly ? Poly is not that expensive .
Maybe I can get poly driver side only and Poly transmount ??
Just trying to save so I can get other go fast parts .
Any help would be appreciated
salvageV6
Senior Member
#2
Driver poly. HR Parts, pass. stock all you need.
I got a little vibration which didn't bother me at all from the poly. tranny mount but it holds up well with oil leaking on it all the time. I would probably just use a stocker if I needed to replace one.
I believe there are different poly. types to choose from now for motor mounts I have the original stiffer HR Parts poly. drivers side mounts and many miles on the two I used.
Just my .02.
Approx. 400-425 HP to rear wheels on my cars.
