Mototron 60# injectors with matching TT 6.1 Alky chip
2QUIK6
Turbo Milk Jug displacmnt
What is the stock front wheel stud thread size? Trying to find some that are about 1/2" longer than stock and not sure what the thread size is. Anyone know of any vendor that sells some longer than stock? Order new rims and it appears I have the backspacing slightly off for the tires I have to run on them, 17x8.5" rims with 4.3 backspacing and may need to run a small spacer.
m12 x 1.5 and you can get longer studs (2") from most chain stores or summit dorman part number 610-323
Thank you, exactly what I needed! Wasn't sure about all of the other dimensions on the knurl size and diameter!
