Moved turbo housing to match int
5ltretr
Unable to control boost now after the housing move?
I hit 20 PSI this morning (3KR) then let off the gas.
Which way should I move the adjustable wastegate?
lengthen rod for less boost.
You may want to start by lengthening the rod so that it slips over the w/g arm. See what that gives you, then shorten for more boost as needed.
thanks I will try that.
I had very good control over the boost before I made the change.
