MSD7AL-2Plus
LikeMySix
Trying to install one of these, using the MSD distibutor and the XFI. Already have the ground plug for the harness and the cam sensor plug adaptor. My question is directions on the ignition box show the M+ and M- plugging directly to the distributor. Do I splice into the cam sensor adaptor plug to run these wires to the ign box, or dont run them to the ign at all, or what?
TIA
TIA
No, you use the white points wire to trigger the box only.
I ran power and ground to the battery lugs separate from any other wiring and have had no problems.
