Originally posted by Lbraucht
he well not shut up saying he will beat me
See if he'll run for money. Next time he starts his BS, challenge him to race for money. If he says something like, "I don't want to take your money", then tell him, "I figured you'd come up with that as an excuse. So if you're not going to race for money, then shut the funk up. Put your money where your mouth is."
If he does accept the your challenge for money, then you need to determine a time and a place, the amount you're going to race for, the conditions of the race (lenght, from a stop or from a roll, etc), and get a 3rd neutral person to hold the money in advance. If he doesn't agree to any of this, then tell him stop bothering you with his childish tauntings until he's ready to grow up and get serious.
The bottom line is he either puts the money up
in advance or shuts the hell up. In no way do you race him unless you see the cash.
to bad the GN on jacks in my garage because we just put new motor mounts
If the GN is not modified in any way, then you'll have just as much chance or beating him with the Mustang. The '99+ GTs run pretty even with my stock GN at 14psi of boost, which is in the low 14 to high 13 second range.
I hope you're a member at the
Corral. They'll show you how to make that Mustang a little bit quicker.
EDIT:
pt51 turbo, THDP, MSD 50# , 2800 stall converter, adulstable chip, 340 walbro pump, adj. fuel pressure regulator, hot wire kit hopefull low elvens haven't run it yet with this combo
I see the GN is not stock. Racing him in that GN would be about as much fun as beating up a child.
