Either the rear main is leaking or the pan is loose.
Sorry about the hijack Jim.
I agree..most likely a rear main seal leak.
SignUp Now!Either the rear main is leaking or the pan is loose.
Depends on how they are pumbed. But both should see vac and under boost see boost. Check your oil return line on the intake. They like to lift up and shot oil down the back of the block.its holden up nice i just have oil leaking bad and its blowing on my exaust so i cant drive it and the 2 vacume lines that go on my wastegate actuator does one blow and one suck or do they both suck or vice versa
I remember reading the too a number of years ago.Damn it's been 7 years I knew about that and kinda forgot.
I have a Pats 12" 2800 stall that I pulled out of the 86. Think I'll send it in somewhere to have it freshened up.Well get rid of the converter and go from there Jim. It shouldn't be hard to change it back to LU so you are ahead for now. What're you thinking about as far as stall?
I found the paperwork, will ship soon![]()
Get a 10" from Dusty, Jim. I've been PMing him about converter choices and from what he's posted you'll be happier with the 10". More effecient than the 12" and less rotating mass, so it will spool better for you.:biggrin:
Sorry fell under a rock...But it finished yesterday, got screwed, but ...I'm a free man and I have the kids. :biggrin: Time to start cleaning out the garage and ship somone something![]()
