If you do the wideband with a turbo tweak6.0 chip it will tune to your desired af. The first things you need to do is fuel pump, hot-wire, adj regulator,60# injectors, scanmaster. Then from there upgrade
I like the sound of that. How does a chip know the a/f? Am I splicing the 5v output into a harness? Pin out? An adapter? I'll Google the chip. Thanks.
Pump, hot wire kit, FPR, and 60#s are on the way. Next, from the sound of it, is to get a Scanmaster
Run the stock ecm, keep the stock boost soleniod and use the adjustable rod on the actuator to dial in the boost. I run the Boost Commander for adjusting the boost. It's nice to just turn a knob.
I'll look that up as well. A type of electronic boost controller? I imagine I won't be running a LOT more boost, seeing how I'm on 91oct. I've decided on a front mount as a bit more insurance from detonation.
This is turning out to be much more simple and cheaper than I thought!
