I tried doing a search on wheel hop but to no aval.
Anyways I just found out today if I hold my brakes and build the boost up to 5 psi and then let off while stabbing the pedal, I get enough wheel hop that I can actually feel it in the rear end.
In the past just stabbing the pedal off the line and not letting any boost build before hand, I've never felt any wheel hop, though I've set off the knock alarm a few times/had a sudden big number out of nowhere appear on my Scanmaster, so it was probably doing it too, just not enough that I could notice.
I plan on taking my car to the track soon as soon as i can pony up the funds for some drag radials...so I'm sure I'll probably have wheel hop issues then too, so i figure now might be a good time to correct it.
As of now my rear end is 100% bone stock, so I'm sure this is probably most of the reason why.
I'm wondering if replacing the rear control arms with some non adjustable tubular arms will fix the wheel hop issue? Or I saw some "no hop" bars....would those be the answer?
What have some of you done for wheel hop control that actually worked?
Thanks!
Thanks!
