MY E-85 Fuel system
Did some test blasts last night no longer at 100% d/c with E-85 at the same prev maxxed out boost levels!
Rear firewall in with full interior...keeps tech guys happy!
Now I don't know if you know this, but I think your car came from the factory with an extra metal rod across the rear seat.
You should probably ask for a refund or something. I can only imagine trying to get laid and knocking the girl unconscious..
No man didn't you hear that's the S&M tie em up hack em up pkg! ;)
Nice job,
I am looking to run e85. I would like to know what size injectors are you using and how meny psi is the reg set at and what fuel filter are to using ?
Thanks for your help.
83's now but going to 120's in the off season
Base fuel pressure set at 45psi as per XFI
Here is a link to the fuel filter I am using (the shortie version) he is close to me (local guy) also using his o-ringed an fittings where needed and his y block too
http://www.product-engr.com/fuel_filters.htm
Going to use a 10 micron post pump filter after i get the 120.s put in...prob going to use a weldon filter and change monthly
http://www.weldonracing.com/product/25-15/EFI_and_Carbureted_Filter_Assembly.html
-Dan
We have very similar taste :)
Thanks for the compliment and you pics. are out standing nice clean job. I soon will be posting my e85 build as well.
