well if your running 20 PSI then your around a 2.36 PR. ASSuming your wanting 400 hp that puts you in barely the 72% efficeincy range... more likely the 70% area... depending on how accurate this map is in comparison to what the wheel really flows for your turbo.
but you say you have seen this wheel pushed to 3 bar and it was still efficent? that sounds a little far for me.... I bet it will begin to really work at around 27 or 28 lbs. which is what? like 2 bar?
I think alot of the flow your geting is coming from your turbine side.... have you measured that? I bet its like a 301 wheel on a stage 2 turbine.....
I want to see that side now.
A.j.
