SignUp Now! Cann't wait to drive this thing again!!!
  d0n_3d said:you keep that detonation up and you'll not have a motor together for bowling green! why are you getting 20 degrees of knock? what are your 02's during the run and such?
TURBOV6 said:I really think those 009's are not enought to get you into the 10's.
Dam scary with 20 degrees of knock and 30psi of boost! I hope you have a set of headgaskets ready!
TURBOTIMMER said:I was told they were good for about 121mph. QUOTE]
I hope so
I really think just spending and extra few hundred bucks on a set of bigger injectors is good insurance.
But then again it's your car. Good luck getting into the 10's with the 009's!
 Put some hydrants in there
  Put some hydrants in there   and give yourself a legit chance
 and give yourself a legit chanceTURBOTIMMER said:I guess what I meant to say was that 009s would good enough for the high tens, and that should put you right around 120-121 mph. But that's a very generic statement. I'm going to try to get to the track 1 more time before bg, but with a set of 55lbers and a modded ecm borrowed from my other car. Probably should have done that in the first place.
whistlingT said:my car has 009's and it is running 11.56 @118 and they are out of it the direct scan shows over 100% DC. I have a hotwire and walbro and a volt booster. I think that the 009's are good for the 1st 1/8 mile but on the big end they are way lean. I have a 60 series and tuning and data logging. I have a stock bottom end and lightly ported heads a FMIC of my own design and THDP some small odds and ends that is about it.
 I know! The only problem is I sold the PT54 to a friend, I need to buy it back now. How does a stock turbo spool on a 3500 stall 9"norbs said:If you dont run 10s now.......give up on buicks!
