Hi all, especially Joe Lubrant, if you are looking. I put in the reprogrammed chip for my car...thanks a bunch.
Here is a few runs I did today. It was in the high 60's, low 70's today, nice.
I do not know if the columns will line up to be able to read this stuff. I am running about 15-16 psi of boost and 44.5 psi fuel pressure. Let me know if it would be better to send the t-link files(they are in the document format)
I am still getting some knock, especially if I lay into the throttle when going 40-50 mph and the boost comes up to 16 psi or so...goes over 10-12 degrees of kr. I thought this data might help.
Run 1-Boost spikes to 16 and settles at 15
IAC 43 94 94 94 94 94 94 91
LV8 54 175 255 255 255 255 255 104
TPS .42 4.90 4.9 4.9 4.92 4.92 4.92 .42
INT 131 128 128 128 128 128 128 128
O2 Volts 167 832 843 859 820 812 804 273
MAF 7 107 238 224 235 204 215 33
Blocklearn 124 128 128 128 128 128 128 125
O2 Delta ---- 1 0 0 0 0 0 17
Man Air Temp 72 72 72 72 72 73 73 73
Engine Speed 725 2250 4250 3725 4375 3350 3625 2425
ESC Counts 7 7 8 8 9 10 11 11
Spark Retard 0.0 0.0 3.1 1.4 1.6 6.6 3.5 1.6
Coolant Temp 159 159 159 159 159 161 161 161
Road Speed 5 10 24 42 56 67 75 81
Battery 13.7 12.9 13.0 13.0 13.1 13.0 13.0 12.9
EGR 0 0 0 0 0 0 0 0
Run 2- Boost 15-16 psi
IAC 43 86 94 94 94 94 94
LV8 54 128 171 255 255 255 160
TPS .42 2.44 4.24 4.9 4.9 4.9 .42
INT 123 128 128 128 128 128 128
O2 Volts 671 777 855 843 843 808 335
MAF 7 45 117 233 226 237 39
Blocklearn 124 127 128 128 128 128 127
O2 Delta ---- 12 0 0 0 0 25
Man Air Temp 66 66 68 68 68 70 72
Engine Speed 750 1450 2350 4425 3750 4400 2575
ESC Counts 11 11 11 12 12 12 13
Spark Retard 0.0 0.0 0.0 3.1 1.4 1.9 2.8
Coolant Temp 161 161 161 161 161 161 162
Road Speed 4 0 10 28 44 57 68
Battery 13.1 13.4 13.1 12.9 13.0 12.8 13.1
EGR 0 0 0 0 0 0 0
Run 3- Boost 15-16 psi
IAC 26 82 91 91 91 91 91 90
LV8 53 139 194 255 255 255 255 134
TPS .42 2.04 2.62 4.44 4.7 4.78 4.82 .42
INT 119 131 128 128 128 128 128 128
O2 Volts 519 265 832 859 839 828 820 37
MAF 6 54 162 211 238 251 214 127
Blocklearn 123 127 128 128 128 128 128 17
O2 Delta ---- 17 4 0 0 0 25 17
Man Air Temp 81 84 81 77 75 75 75 75
Engine Speed 675 1650 2725 3650 3825 4425 3325 2725
ESC Counts 13 13 13 14 14 14 15 16
Spark Retard 0.0 0.0 1.9 2.1 0.2 0.0 4.0 2.8
Coolant Temp 170 170 170 170 170 170 170 170
Road Speed 3 2 15 32 46 58 69 76
Battery 13.1 13.4 12.9 13.1 13.0 13.0 13.1 12.8
EGR 0 0 0 0 0 0 0 0
EGR 0 0 0 0 0 0 0 0
EGR 0 0 0 0 0 0 0
EGR 0 0 0 0 0 0 0 0
