NA Intake Manifold-Factory Valve Spring Dampeners & Oil Slinger
WE2Regal
I need a facory intake manifold for the NA 84-87 3.8 engine part #25525575. As complete as possible minus the carb. I also need a complete set of the factory valve spring dampeners and an oil slinger for the crank to finish a new build. Thanks.
I have a slinger for sure and also have a intake I just need to see if it the one you need .
I'll keep my fingers crossed. It'd be great to get them both together.
I have these if you are still looking. Have an 85 that is complete but temp sensor is broken. Didn't check the part number but I assume they are all the same.
i got a complete 87 intake on the engine still i can take it off if you need it what you paying for it ?
