NEAL CHANCE bolt together converter for th-400
BLACK MAGIC RACING
formerly turbo_canuck
I'm selling my Neal chance 9" bolt together converter for th-400. I ordered this converter custom from Dan @ DLS. I only ran this converter 2 weekends. I thought the converter was too tight, but it turns out i had tuning issues. I did run my best mph with it, (162). It has all the bells and whistles, billett cover, etc... You can adjust the stall range from around 3500 to around 4200, depending on how u shim it inside. I paid over 2k for this converter, and it has 8 passes on it, TOPS. I've decided to keep my current converter, as it works well, but with slightly more slippage on the top end. Basically, i'm just too lazy to swap out converters again. :p Asking $1200 OBO
dang, Same converter in my buddies Camaro that went 7.80s in the 1/4 and it worked great. Good deal.
Scott
info
what diamater is the conv, and which stage?
set up for T brake?
was this converter bought directly from Neal? and built for your application?
thanks
