This is to do with the check valves in the vaccum lines.  Theres one around the EGR valve and one on its way to the fuel vapor canister, I think thats what its called.  The valve around the canister pretty much works when it wants to.  Its not leaking externally but internally, guess its got a check ball hanging.  How does this effect the vaccum if these valves are inoperative?  Is it similar to a vaccum leak?  This is the only vaccum problem I can find, and my guage is going wild along with my idle and IAC's.  If I plug the line at the valve everything is good.  Would someone explain how this works, I'm too tired to figure it out right now
thanks in advance
pat
			thanks in advance
pat
