Need a qualified GN shop near Cincinnati
Johnnie
Anyone know of a knowledgeable GN shop near Cincinnati ? Gotta find one to thoroughly check out my newly purchased '87 GN.
Thanks. Johnnie
what do you need checked out ?alot of guys around you and im in Dayton
This car hasn't been driven much in the last 5 years or so. I just some need some general things checked, you know like a" 100 point" check like a dealer does. ( brake pads/ shoes checked, ). The ebrake mechanism also gets stuck on when pressed. Sounds like the ratchet mechanism is screwey. I am told it's not the cable.
I will also need transmission filter/ fluid change ,,,,,, just general stuff.... And I do not want to trust this car to anybody. I am SURE you understand.
Thanks in advance, johnnie.
if it hasnt been driven in 5 years needs the tank drained fuel filter,oil,transmission,grease,plugs,IC cleaned out,cooling system flushed,brake fluid and lines cleaned and changed .that would just be a start .if you dint find anyone closer i could look at it after mid october
Lonnie Diers, of Extreme Automatics, is in Amelia if that is close enough?
Lonnie Diers is good people.
If you want I can work on it too but im in Akron.
