Here's the deal i have a stock longblock right know with a built trans a vigilante converter 7disk l/u 32-35 stall std gear ratio 3;42's @ the track cant really hold much boost on the line about 7 psi and i break loose, my 60 fts are best of 1;9 and 7;68 @ 91 mph on the 1/8th on 93 pump and alky @ 22-23 psi timing is kept safe and afr 10.8 well i bought the huge 6765 because i have some ported heads with new springs on the shelf, trying for a custom grind but cant get too much info on custom grinds ppl are secretive??? so i might have to go off the shelf grind, i also have a complete e85 system ready to bolt on, 120's 6.1 chip etc, i really want to buy a turbo that will suite my stock longblock until i get ready to take swap heads and intake and do the cam & e85 swap, i dont mind running 26psi + but i really need some mid 11 passes and if possible faster, what turbo is good for both setups since i would like to use it with my current stock longblock until i reach my 11.5 goal Then go with my ported heads, and a about 212 cam e85 +28+ psi i dont want to spend double money which i already am because i bought this bigbb 6765... my buddy told me to run the stock turbo @ 28 psi and i should be able to run high 11'90s with a 1.6-1.7 60 ft.. but rather buy something that'll suite both setups and keep the 6765 on the shelf for future setups or i might sell not sure? some input pls. saw bison has the 5857 on there, but thats more for stock converter type of deal..not sure was thinking te45 or a te60 te63? 6262
