need advice fast !
bigmike
First of all I just joined and the GN chassis is somewhat new to me I am from the subaru world where everything can be done with a lap top ( much easier ) and am somewhat confused about this extender chip thing ...
here is the deal a friend of mine brought me his 87 buick GN orig 48000 on the clock and original owner it wasnt running to well .it was nosing off up top and the scan master showed it pulling timing all over the place no matter what I did to boost levels and fuel presure .
original set up was
Jay carter chip
36lb injectors
3 inch down pipe
precision TA 49
short ram intake with K&N filter
art car trans kit
street brawler 12" lockup converter 2800 3000
2.5 exhaust
adjustable FPR
the little box to adjust tps with small led's
scanmaster2
FP gauge on hood
oil pres
boost
volts
trans temp
economy gauge ( useless )
so while surfing the net I found GN1 performance and called archie told him the set up and what it was doing he gave me his recomendations
bigger intercooler
his extender chip
60lb injectors
so I did the install of all this stuff set fuel pressure to the recomended 37 40 psi at idle checked that everything was good thru scanmaster and took it out . it seems to have better throttle response and off boost power but if you just whack it scanmaster shows 1.5 to 9.5 or higher of timing retard and you can hear pinging BAD so I lowered boost to 10 psi form 15 psi ( 15 is what was recomended to start off at and go higher from there ) toped off the tank with fresh sunoco 93 and still the same thing but not as bad but still there . now if you feed it throttle slowly and progressively its fine and seems pretty fast but who wants to do that all the time I have been told the parameters of the chip can be changed via the scanmaster through a wire that came with the chip that would have to be spliced into the ECU harness is this so ? any and all advice will be appreciated ...
there are no vacuum leaks that I can detect . it idles fine , no smoke out exhaust, at full throttle it shows O2 at 800 to 820 ( wanted to start high and work it lower ) The chip I was sent was marked 48psi / 104 octane but I was told by GN1 performance that it would be fine :rolleyes: I think this is the problem as it seems as the timing curve is too aggresive or transional fuel is messed up . I hate not being able to log this car any insite ???
Mike
Could be a million things but step one is that the chip is not right. It's providing fuel for a system set at 48psi (not 40), and you may or may not be running 104 octane.
Other than that, sounds like a typical fuel/timing problem like most of us have seen before. If you gradually get into the gas pedal it's okay, but if you romp on it and boost builds too quickly, fuel can't keep up and you get detonation.
I am not sure about how to make adjustments in that chip. I highly recommend going to a turbotweak chip programmed PROPERLY for your setup.
TurboTweak Home
Make sure that you are adjusting the fuel pressure with the vacuum line going to the FP regulator off and blocked.
You didn't mention anything about a fuel pump. If not already done, install a Walbro fuel pump and what's called a hotwire kit. These buicks do not have very good wiring going to the FP and doesn't receive the proper voltage.
I wouldn't use that chip unless you have 104 octane fuel. With that amount of knock, you will blow a head gasket or kick the crank out of the block !!!!
yes it does have a walbro 304 with hot wire set up ... what I dont understand is I told the vendor the set up I was working with and I got a 104 chip and then was told it would be fine ...
104 chip
:eek: Why he sent you a 104 octane chip when he knew you were running 93 octane doesn't make sense. He should have sent you a street chip with lower timing, and lower octane requirements. You are where you started minus your hard earned cash, IMHO don't think another vendor would have sold you a larger IC and 60#injectors to fix your problem they would have steered you to tuning basics 1st, you now own a larger IC and larger injectors and a chip that doesn't go with the octane and combo your running. You ought to send all that back to him. If I was into doin over the phone fixes/tune actually would have encouraged you to fix any thing that could cause false KR(DP hitting frame) might have tried racegas to see if any of that KR went away, or a spring cleaning there was other things to check out before going bigger IC and Inj., think you would have been better off trying a Razor alky system with a TurboTweak alky chip burnt for your combo Ta49, 36lbers, 3000stall... and start with lower boost pressures tune ,tune ,tune. You need to get rid of that little box with lil lights that hooks up to your TPS and adjust tps settings(idle/wot) correctly using your ScanMaster. You might reset IAC 1st then TPS.
Give them a call tomorrow and let them know that is is a 104 chip. If they tell you it is OK to run with 93 gas, ask him to put it in writing. When the engine blows, you get a new engine. :-)
Seriously, give them a call. Most Buick vendors are pretty straight up and will send you another chip. They may even send it out before you send the wrong chip back.
I have a call in to him now as well as an Email but nothing back yet ( could be the holiday ) I will try again tomorrow . the reason I went to a different chip is because the original chip was malfunctioning no matter what octane and boost I was running in it . I narrowed it down to the chip and was recomended calling GN1 performance by a member of a subaru site I am a member of . I am not knocking anyone here just trying to compile information . what I would like for this car is a plug and play chip for my set up I dont really need anything I would have to tune or even want it for that matter . all the pressing the gas pedal and pushing buttone just confuses me I am used to using a lap top and seeing everything infront of me I am only looking for low 12s with this set up ...
I also was getting a lot of knock under boost recently, along with another problem- blm's of 150, indicating a big vacuum leak. Seams when I got the vacuum leak fixed, the knock went away. BLM should be 128. Check that first.
Simple plug n play chip with excellent performance as some one already mentioned Turbo Tweak (Eric) ($85) best $ you could spend. get in touch with him off the website call him tell him what you have on the car he'll do the rest.
check to make sure all vacuum hoses are on
look at each fuel injector make sure they're plugged up & working you may can unplug one each at a time while idle to see if anything changes like a stumble or something once unplugged then you know that ones working.
look at your chassis on the passenger side and look at your down pipe to make sure its not rubbing on the frame, a-arm , fender well, make sure you shake it firm & its not wiggling against anything
make sure your boost lines are connected & not in the wrong configuration
you need a ( wide band) or fuel guage (mechanical)on the hood or (electric)inside to see what your fueling is at WOT should be around 60 or 65 psi...... at idle 43 + or - 2 i think if its too high you'll start leaning out from what i understood. 48 seem kinda high with your injectors, if its too low fuel lines, filter or pump or pump filter clogged. Do you have a power plate?
you can run a laptop on these cars with the right set up from full throttle
with a data logger, maft pro etc.
the thing is it was running ok minus the original chip malfunction (which I think I found out why it was doing what it was doing ) but the owner wanted more power so I inquired another GN owner and was refered to GN1 performance and got his bigger stock location intercooler , injectors #60 and extender chip but the chip was marked as a 48psi 104 octane and I am being told that it should be fine . even after I inquired about a less aggressive chip he was infatic that the chip I have is ok and says I need a fuel pump ,bigger MAF, translator ETC I called cottons performance and right away I was told that the chip is most likely the culprit but was also told to call back when jack gets back .. I will keep you all updated ...
BigMike
It's too bad he didn't sell you a Razor Alky kit in the 1st place instead of injectors and IC,,,,
here is the deal ...
I was sent a set of 60lb siemans injectors which from there site they are high imp, I am being told from the vendor they are low imp, a chip that was marked 42lb /104 octane and a bar & plate stock location streatched intercooler .
I inquired about the chip when it got here and was told it would be fine. and against every thought I had I installed it along with the injectors and the intercooler and the car runs like complete crap ! I call the vendor and inquire again and I'm told to install a new fuel pump ? ( walbro 340 ) already have a hot wired 307 and to buy additional stuff from him to make it run correctly . after I had already asked him if the set up I bought was going to be plug and play and was told no problem it will be exactly what you want .well it isnt ! and he will not exchange anything nor will he refund any $$$ he did say if I sent the chip back he would get me a less aggressive chip I say it was the incorrect chip to begin with but he refuses to admit he was wrong when we all know different ( I AM SO PISSED OFF ! ! ! ) I could really get myself in trouble thank the almighty he is in california and I am in Mass .. well the car is off to cottons performance tomorrow and I will have to foot the bill for a friends car that I was trying to help out because of this vendor ( isnt it always the case ) so if anyone needs a RACE 104 octane extender chip let me know I will also have a set of high imp 60lb injectors for you FAST guys
I really hate being a nice guy I say beware of this guy
BigMike
Man I'd be pissed off too. Glad your taking it to Jack's he will get it figured out for you. So your putting the bluetops back in? Some confusion what 60lbers do you have Siemens or Motrons? What's nice about Motrons is they are high impedance so they work in our cars without modifying ECM. Hope he didn't sell you low impedance injectors. If your buddy is even thinking about going bigger Turbowise he ought to seriously think about keeping the 60's if they're Motrons. I wish I'd gone with Motrons 60's instead of 009's when I went with a larger turbo. BigMike If I could afford them right now I'd take em' off your hands. Hope all this gets worked out and you and your buddy stay friends thru all this. You were trying to do him a favor then this vendor takes advatage of the situation and sells you a bag of goods. Then he even has the nerve to try and sell you more stuff. Thank the Lord Almighty you are on the other coast. Peace
UNF$@KING BELIEVABLE!! :mad: I would definitely relay this story in Vendor/Feedback sections.... :mad: :mad: :mad: (Note to self..... never, ever, ever, ever recommend that douchebag to anybody....) Arrgggg.. I'll be interested to see how Archie's loyal supporters defend this one....
Proof that tossing money at a car won't make it any faster, for sure.
There are a ton of great people on here that will get you sorted out and going fast for sure!
I would start with a Turbotweak chip matched to your combo, start with 93 octane and 14 psi and go from there. It sounds like you know your way around boost already and its not you that's wrong its the combo. Make sure the injectors and ECM imepdance match - you can probably keep the injectors ($) you have if the ECM and chip are the right pieces.
Also, BE SURE TO "baseline the car" - IAC, TPS, MAF, O2, Cam sensor, etc - make sure all are adjusted properly and providing accurate values to the ECM. Make sure NO unmetered air gets in between the MAF and turbo. I would go 42-43 psi LINE OFF and plugged. Make sure the fuel psi increases LINEAR (or nearly) with your boost pressure; ie 53 psi fuel pressure at 10 psi boost, 58 psi @ 15 psi boost, etc. Sensor settings can be found many places here or www.GNTTPYE.org.
Sounds like a CRTL+ALT+DELETE of sorts here; and you have plenty of hardware already to go fast. Cover the basics.
I may be wrong but this ideology seems to always have worked for me.
HTH
Chris
By the way,
KNOCK RETARD IS BAD.
Make sure there isn't any!
Don't drive it this way, or especially let an inexperienced GN/TR friend or customer or you will join the ROTC - the "run over the crank" club.
:D
Really makes ya wonder what he was Smokin that day to sell this guy that line of BS!!! Hope you get Jack to straigten it out for ya! Tell him what happened as well. he has some pull with the Buick Crowd!!
To everyone here ,
Thanks for the support! it really means alot .
I knew from the second I saw the paper that came with the chip ( 42psi / 104 octane ) that something was up BUT I did what I usually dont do, second guessed myself because I wasnt too familiar with this platform . I do come from a turbo back ground ( motorcycles , subarus, snowmobiles ) and basic high performance engines and should have listened to the hairs on the back of my neck that stood up . but anyhow I spoke with Jack today in person when delivering the car off a flatbed and confirmed my thoughts . the injectors are motron confirmed by Jack so there was a little relief there . Jack also said the intercooler was ok somewhat cheap but not bad for the price I paid for it and it is big. I left the car with him for a new TT chip new fuel pump ( for headroom ) going from a 307 to a 340 its already hot wired and he said he would tune it ( not that I cant but what the hell its not like he doesnt know what he is doing ) I am hopeing for a mid to high 11 pass with it after I get some rubber on the rear . think that is too much to ask for ?
87 GN T top
precision TA49
K&N intake
60lb injectors
TT chip
340 pump ( hot wired )
adjustable FPR
3inch down
highflow cat into 2.5 flowmasters
bagged rear
rear braces
front braces
1.5 stock location bar & plate intercooler
front lower air dam that directs air to cooler scoop and air intake with correct plumbing
art car shift kit and trans rebuild
street brawler orange 2800/3000 12 inch converter with lockup
scanmaster
oil pres
volts
trans temp
water temp
audiable knock light / gauge ( new )
now I need some wheels for it and some rear tires and a few track runs will be in order . The owner wants low 12s I am hopeing for mid 11s
again thanks for all your help and support as for posting my story in vendor review. I usually dont get into this he said she said crap on the internet and am going to give him one last chance to redeem himself . thanks again PS if anyone has any suby questions feel free to ask
definately get some tires but with out sqeezing the guts out of that 49 turbo , unless youre a pro at tuning like some of the others, and i could be wrong but in this hot weather id say mid to low 12s also. if you stay up north by Jack then on a gooooooood cooooooold day in the late fall maybe a high 11, maybe. with super high boost. jmt its easier said than done.
