Coelacanth
- Jul 7, 2014
So, I finally had time to drop the fuel tank and replace the fuel pump with an upgraded Racetronix pump. I also have the fuel pump installation kit with the new sock, piece of fuel line, O-ring gasket and hose clamps. I ran into a snag when trying to follow the Racetronix fuel pump R & R instructions. Firstly, the original fuel pump completely lacks a plastic connector, it just has 2 wires with spade connectors; a grey/brown one and a black one; grey being the positive, evidently. Furthermore, the OEM spades will certainly not connect to the inside of the small connector end of the new wire connector, and even if they did, they'd be way too close to each other for comfort.
Am I fine to just cut that small connector off, cut the spade ends off, and simply solder the wire ends to the new wire connector with some heat-shrink? As this will be inside the gas tank, will the heat shink degrade? Has anyone else run into this problem and have a better suggestion?
I tried to capture everything in a single picture; the aging yellowed pump is on the left; the Racetronix one on the right. The 2 wire connector ends on the far left.
I'll be Dremeling down both ends of the feeder tube a tad to remove the sections where the inside diameter narrows down unnecessarily.
Thanks guys!
Thanks guys!
