11secmonster
- Jul 11, 2005
WANT TO KEEP MY CAR BUT NEED MORE SPEED...HERE IS MY SPECS...I WANT TO GO INTO THE 10-10.5 SECOND RANGE....WHAT SHOULD I CHANGE?
BIGGER TURBO? IF SO WHICH ONE?
HERE ARE MY SPECS..............
precision turbo te 44polished and ATR crossover.
completely redone cevlite bearings.
high volume oil pump,
Reeds 210/205 cam with new push rods lifters a special rocker arm set.A precision oilturbo saver remote oil filter.
New timing chain .
new timing cover
new water pump. Heads have a 5 angle valve job :
50lb injectors, msds, accel wires the expensive ones .
100.00 Kenne bell fuel regulator,
big 340 walbro intank fuel pump,
Tony dequick v4 intercooler,
larger radiator :
Terry huston down pipe, with stainless steel exhaust dump,
hooker aerochamber mufflers tru dual 2 1/2.
Rear end is built with a Easton posi unit with 3.42 gears:
long wheel studs, chevy s 10 heavy duty wheel cylinders (thats so you can hold a lot of boost off the line) it also has aluminum drums.
The transmission is a built 200r4 all ART car with there shift kit and 3000 non lock up converter.
solid mass air pipe,
it has a torque strap that straps the engine to the frame. This car also comes with all the chassis braces behind the rear seat and under the hood.
the engine was assembled using all ARP head bolts.
the suspension is all brand new Billstein shocks and it comes with eibach springs, cragar chrome pro stars for wheels and bf gs for tires. also has a k@n air filter with K@N engine breathers. This car also has a precision turbo te 44polished and ATR crossover.
SMC alky alcohol injection brand new install.
New timing chain .
new timing cover
larger radiator :
