Need big time help and tips !!!!
turbobooster
I'm trying to remove my front drivers seat and I've got the front nuts out and the 2 nuts on the backside near the door and one but from the other side closest to the passenger seat but I can't figure out how the hell to get the other but out there's no room to get in there any help please on how u guys are able to get to that nut?
Sure looks like a short swivel socket will slip right in
Bryan
I don't see how a socket would even fit in there I can barely get a wrench I'm there :/
Go under the car and spray pb blaster on it then use a gear wrench after it sets you can also tap on it to help loosen it up
Spray blaster on the nut and let set a fine tooth angled gear wrench will help.
I couldn't follow the text description all that well and this may sound dumb, but... Is the seat slid all the way forward on the seat tracks?
I've removed my seats a couple times and don't recall any heroics getting the tools in place.
X2
To remove the front seat bolts move the seat all the way back, "on the tracks" to remove the rear seat bolts move the seat all the way forward. It should take about 5-10 minutes. Hope this helps.
Thanx everyone for ur input..... I think my seat motor is shot and and the seat is all the way back maybe that's y I'm having so much difficulty getting to that last nut ..... Another thing whats the truck to pulling the rear black plastic covers that go over the nuts ? They look so easy to come off but mine don't snap off that easy I can almost bend the shit out of it and it won't come off
there is a small screw that holds them in place at the top of the cover.
