Originally posted by mycarsucks
You are fast again bruce
This is from the MS Features page"
I assume that the acceleration enrichment would be equivalent to PE. I could be mistaken
AE accleration enrichment..
PE power enrichment.
AE is a temporay condition to supply fuel for accleration.
Power enrichment allows for changing AFRs due to TPS.
It's IMO, and seemly GM's, to be able to cruise in a near stoich condition, and then change to a power mode without having to make a drastic change in MAP to get the fuel enrichment for real power. This is especially beneficial, again in MO, with a turbo application. Since you have have entirely different fuel needs at at given air flow, ie N/A vs Boosted.
Now if you look at like the Syclone code, they have the VE table for stoich, then a commanded PE AFR based on the VE table, and then a boost multiplier. A very compact, effiecent way of handling fuel. Toss in a AFR vs MAT, and you have about the best there is. The qualifier to about the best is how much resolution you devote to the about corrections. The Sy stuff is close, IMO, just needed a bit more resolution, again IMO.
Now remembering that GM does routines in loops, they can really do a good job with them ole slow processors.
