Buickforlife
Tyler Northcutt
 - Aug 18, 2008
guys thanks for all the replies. This is going to be a weekend driver. Any wehere i go is at least a 20 mile drive so it has to be reliable. I was thinking around 600 HP. Im only looking to get into the low 12s or high 11's I want to do a little better the just passing a $hitvick
Buget... lets say around 3k. not including the timming cover i want to chage that regardless to TA updated one. The most expensive thing for me will be the parts. I want start buying things now and over the winter put it togeather.
who ever said to spay... the car is set up for it from the previous owner. I just need the carb kit. I thought that would do more damage then a turbo. if i sprayed it I think i would have an ichy triger finger...
Some one mentioned (Magnafuel 500 is a great pump) i have 2 fuel pumps in the car from the previous owener the seem do work. Can they be rebuilt. they have not been used since 1989
With out changing the heads b/c they are big bucks. do you think i can turbo it as is? and when i want do better heads I do that? Im not 100% sure on the carb. it might be bigger. Can you tell what it is by looking at it?
Is there a turbo that i can put on now and will leave room for growth. I have a shop by me that can do all my welding needs and more (JP crawlers).
Are any of you guys in the NY area?
Either one can do more damage than leaving it NA, if you don't tune it right.
