85begalttype
just a v6
- Oct 22, 2008
85 t-type pretty much stock(afpr, 86 ecm, tt chip)
readings at idle, warmed up, iac around 20-30, tps is at .46, maf at 5, o2 is around .700, blm is around 129. fuel pressure line off is around 43#
from cold start to warmed up, engine idles alright, some little stumbling. When i put it in drive then park again, or when turned off and then on again, it misses and stumbles bad. my o2 reading goes down to around .10 and sometimes zero. so i guess it starts to run lean. then i give it some gas and the o2 goes around normal again for a bit.
found no vacuum leaks, i unplugged the maf and it almost stalling. unplugged the cam sensor while running and it dies right out.
maf, o2 and iac are all new. seems like the only things left are either the cam or crank sensor. cant even see the crank sensor from overhead. cam sensor is that round cap above the water pump?
car runs great when driving around, just doesnt idle without stumbling and missing
